power supply help
Discussion in 'General Electronics Chat' started by slashonthenet, Mar 18, 2009.
  1. slashonthenet
    Feb 5, 2009
    Hello. I need help changing a 24vdc 6a power supply to a 5vdc 40ma to operate a 555 chip. any suggestions
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It would probably be easier and lots cheaper to just get a 7 - 9 volt DC wall transformer and a 78L05 voltage regulator.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I certainly agree with beenthere:
    However if you have the 24V supply at hand and are resolved to use it, you could build a small LM7805 regulator circuit:-
    http://cva.stanford.edu/classes/cs99s/datasheets/LM340.pdf
    As long as you keep the LM555 load circuit current to a conservative value say ~70mA max, you could probably get away with a TO-220 package without any heat sink (assuming a maximum ambient temperature of (say) 40 C and R thermal(J-A)=55 C/W ).
    If you are confident with electronics construction you make it something like this ..
    http://peterflemming.ca/flemmweb_current/schem/opamp_linear/7805.pdf
