power supply help ...need (+/-) 12v audio grade bipolar supply
Discussion in 'The Projects Forum' started by rockreid, Oct 23, 2012.
  1. rockreid
    Oct 23, 2012
    I am building a large modular synth case and am looking for a suitable bipolar power supply (+/-) 12v with at least 4 Amps output. Any help would be appreciated.
  2. wayneh
    Sep 9, 2010
    12,374
    3,225
    Go take a look at Parts Express. You'll get an idea of what's available.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    http://www.linear.com/product/LT1084-Fixed
    not sure about a 4A negative linear.
  4. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    You could use two of the LT1084's , if the transformer has two separate 12 Volts windings.
    You could stack the two supplies then.
    Bertus
  5. t06afre
    May 11, 2009
    5,939
    1,222
    It is also important that you dimension the transformer correct. Do not get any transformer before conferring with us. If you want to draw 4 ampere continuous. A 4 ampere rated transformer will not do.
  6. bountyhunter
    Sep 7, 2009
    2,498
    507
    Correct, that is the best way to go. Just make sure the negative reg is electrically isolated from the heatsink.
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    If you are feeding it into a FWB/capacitor to get the unregulated DC, you will need a transformer rated for about 7A RMS to supply 4A DC load current. With 12V output, the regs need at least 15V. I think you need a transformer rated for 14VAC secondary to allow a bit for ripple and load regulation effect. That would be a transformer with two 14VAC separate windings, each rated for 7A RMS.
