power supply for two op amps?
Discussion in 'Homework Help' started by caoadon, Jul 21, 2014.
  1. caoadon
    Jul 11, 2014
    24
    quick question.
    Can I power two op amps with the same power supply source?
  2. shteii01
    Feb 19, 2010
    3,505
    512
    Yes, you can.
    Also if you have a chip with two op amps build into it, they share power and ground so you only need two wires instead of four wires you would use with two chips that contain one op amp each.
  3. caoadon
    Jul 11, 2014
    24
    thank you sir!!
    edit: oh okay. Unfortunately i have two individual op amps so i gotta use 4 wires haha
  4. shteii01
    Feb 19, 2010
    3,505
    512
    Nothing to be sorry about. It is part of learning. There is a Russian saying: measure 7 times, cut 1 time. Meaning do some planning before you start actually doing "stuff".
    On the other hand. Let us say that you need one op amp to work at 5 volts and second op amp to work at 10 volts. Then you would actually want two separate chips.
    Bottom line, and probably the most important point: you work with what you have in your hands! Which means that if you have two chips, you use two chips. Like I said above, nothing wrong with it.
  5. donpetru
    Nov 14, 2008
    186
    25
    Do not forget to bypass power rail with capacitors (0.1uF) for each operational amplifier.
  6. caoadon
    Jul 11, 2014
    24
    do i still need to bypass a unity gain op amp?
  7. donpetru
    Nov 14, 2008
    186
    25
    A capacitor near IC pin power "never hurts".
