Power supply for the experts
Discussion in 'The Projects Forum' started by Slanwar, Mar 7, 2015.
  1. Slanwar
    Mar 7, 2015
    5
    I want to build a power supply (I know buying one is cheaper) and I'm not using a computer ps because I already have one. The project:
    Output with a range from 3 volts to 30.
    I will add 2 digital panels to read amps and volts.
    What I need;
    Transformer (need specs here)
    Voltage regulator (LM317?)
    Can someone design a schematic for me with all the values and what I need?
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    Roderick Young likes this.
  3. Slanwar
    Mar 7, 2015
    5
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    They show the common connected to earth ground, you may want to float it if a bench supply?
    Max.
    planeguy67 likes this.
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    The amount of output current you want will determine the size of the heat sink you will need for the LM317.
    For example with a 1A output at 3V and a 35V source, the power dissipated by the LM317 is 32W, which requires a large heat sink. For that you might consider adding a cooling fan to reduce the size of the sink or a heat sink with a integral fan like those used for cooling PC processor chips.
    The transformer should have a current rating about double of the maximum DC current you want.
