Power supply for DC motors
Discussion in 'General Electronics Chat' started by dmta, Aug 24, 2013.
  1. dmta
    Mar 24, 2013
    32
    Hi all,
    I need a variable power supply to control 2 H bridges which drive 2 DC motors. The max output current and voltage is 5A and 20V respectively. I have designed the following circuit based on Dave Jones's lab supply where the output voltage and current is set by filtered PWM signals.
    What can I do to improve the stability and quality on this design? Can someone recommend a better power transistor for this as I find it a little hard to choose one. Your input will be most valuable.
    Regards
  2. wayneh
    Sep 9, 2010
    12,390
    3,246
    You can buy very inexpensive motor controllers on e-bay these days. It's more expensive to build your own.
  3. Alan brad
    Aug 29, 2013
    9
    I have a 24v/20A supply on the bench right now. It is a Mean-Well SP-480-24...
