I'm building a power supply based on the following two sites:
http://www.aircraftspruce.com/catalog/cmpages/hotwirekit.php
http://www.instructables.com/id/Hot.../Wiring-up-the-transformer-and-dimmer-switch/
but I want to add a fuse just in case the output wires are shorted out. This would be different from the normal fuse in power supply construction which is a slow blow on the primary.
The transformer is rated at 2A
http://www.hammondmfg.com/266.htm
so I'm guessing that if I put a 2A fuse in the xfmr output I should be okay.
I've got some fast acting 2A automotive blade fuses (ATO2BP) at the top of:
http://www.littelfuse.com/data/en/Data_Sheets/aftermarket-5.pdf
Does this sound okay?
Thanks,
Peter
Thanks,
Peter
