I need a circuit, when higher voltage is occured, it should normally conducts the voltage. But when the lower voltage is occured, it must boost or double the voltage. for example, if my input voltage is 15V, output voltage must be around 14V. if my input voltage is 3V, it should boost the voltage say about 6V. Is is possible? is there any component to do that? Please help
