Power Supply Design
Discussion in 'The Projects Forum' started by sudakshina_das, Apr 18, 2011.
  1. sudakshina_das
    Apr 18, 2011
    Hi! I need to design DC power supply. I am using a transformer first, then a rectifier and finally a voltage regulator. But I was not able to get hold of a -60 V voltage regulator. Please help me in this regard. Also are there any other ways to design the power supply? Thanks a lot.
  2. mbxs3
    Oct 14, 2009
    143
    What do you need the supply for? If you provide more information then someone may be able to help you. What do you want the power supply to be capable of supplying?
  3. sudakshina_das
    Apr 18, 2011
    I am looking for a +/- 60 V power supply for a piezo device. The supply is for the amplifiers.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    How much current? What is the unregulated voltage of the bare bones transformer, bridge, and capacitors (and the values of the components you used)?
    Schematics are always nice, to prevent assumptions.
