I am working on a project which requires power supply of +/-60V DC. I found a positive voltage regulator(TL783) which can work for this high DC voltage. But, I found it difficult in searching for a negative voltage linear regulator. If you guys have any suggestions of creating a negative voltage supply of this range or if you know any linear voltage regulator this can provide me this range please help me. By the way my project requires a power supply which can supply currents up to 0.3A.
I also though of a circuit which can be used to generate +/-60V volts from a single 120V supply using a opamp and some resistors. But this requires a regulator with a positive and negative terminals. I have attached that circuit to this feed. Can you suggest any such voltage regulator.
Thank you,
Regards
satya.
Thank you,
Regards
satya.
