Power supply design for 6volts and 20watts for halogen lamp
Discussion in 'Homework Help' started by subbusuccess, Jan 17, 2009.
  1. subbusuccess
    Jan 17, 2009
    Please suggest me a circuit for a 6volts and 20watts power supply for a halogen lamp
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    How about a transformer rated for enough current?
  3. subbusuccess
    Jan 17, 2009
    Transformer should have 12-0-12, 5 amps
  4. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    The voltage your transformer is supplying is to high.
    You will have to make a regulation circuit to bring it back to the required 6 Volts.
    For 20 Watts the regulator must be able to handle 20 Watts / 6 Volts = 3.4 Ampere (rounded up).
    Greetings,
    Bertus
  5. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Run it off a 9-0-9 3A transformer... A 9-0-9 will give near to 14v and wont need a regulator... 12-0-12 will give 18v which can be regulated to 12
