Power Supply Calculation
Discussion in 'The Projects Forum' started by krishnan_hari83, Feb 14, 2012.
  1. krishnan_hari83
    Feb 11, 2012
    21
    Guys,
    Please clarify my doubt.
    I am having 3 LEDs each of 4 V and 120mA.
    What is the power supply I must give under the following conditions.
    1. 3 LEDs connected in series
    2. 3 LEDs connected in parallel.
    Kindly advice me of the power supply calculation.
    Krishnan.H
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    In series u will need more than 12V @ 120mA max & one resistor.
    In parallel u will need 4V @ 120 X 3mA
    But I doubt this way would be advisable.
  3. wmodavis
    Oct 23, 2010
    737
    150
    For series - 12 V @ 120mA
    For parallel - 4 V @ 360mA
    But as R! suggests best to have resistors which will limit current.
  4. mcgyvr
    Oct 15, 2009
    4,784
    973
    I always wonder how many millions of LED's have been destroyed in the past 10 years because people think you can just hook them up like a light bulb and off you go..
    Your power supply could be rated for 100V @ 50 Amps and still work just fine provided you include some sort of current limiting into your schematic (like a resistor in series with the LED to limit the current or other constant current supply)
  5. studiot
    Nov 9, 2007
    5,005
    515
    You might like to consider a series connection of two parallel pairs.
    That way you can run from a 9V battery and a 4R7 half watt resistor.
