Power Supply Board Ripple
Baskaran Manoharan
Joined Apr 18, 2016
5
I am using 19.5V/4.5A power supply, measured the Ripple Voltage across the load It is almost 140mv ,After 10min again i measured Ripple voltage on same load its reduced to 40mV How is it?
wayneh
Joined Sep 9, 2010
17,498
Putting it another way, the question cannot be answered unless/until the load is known when the ripple measurement is made.
BillB3857
Joined Feb 28, 2009
2,570
Has the power supply been out of usage for a long time before these tests? If so, the output filter caps may have "deformed" and after a while, "reformed" to a proper value. Electrolytics can sometimes behave like that. It is not uncommon to connect replacement electrolytics that have been in storage to a slowly increasing volgtage up to near the rated voltage of the cap. This allows the electro-chemical reaction needed to form the dielectric barrier.
