Power Supply-Amazon
orbiter
Joined Jun 17, 2010
58
You may also like to check these out.. I have the 5A version and they're pretty good units.
http://www.circuitspecialists.com/bench-power-supply-csi3003x3.html
http://www.circuitspecialists.com/bench-power-supply-csi3005xiii.html
As regards the 00's of volts etc, well that depends on whether you require such fine adjustments. For general hobby use etc the one you linked to and the ones above are fine. I know that with the one's in the above links you can control the .0's volts quite easily to the required voltage.
