Hey Forum
If i hace a DC/DC converter and i am drawing 7amps at 24vDC on the
output, ignoring the effeciency of the device with 300vDC at the input,
how do i calculate the current that is been drawn by the DC/DC Converter.
Another type of Power converter i came across recently, i was drawing between
7-8amps at 50vDC on the output, but when i measured at the input to the power supply it was drawing over 10amps for 230vAC. Should you not
be drawn less?
How do you calculate these for such power supplies (switch mode)
Cheers
be drawn less?
Cheers
