Power Supplies
Discussion in 'General Electronics Chat' started by Mazaag, Mar 17, 2006.
  1. Mazaag
    Thread Starter Senior Member
    Oct 23, 2004
    255
    Hi guys,
    I had a stupid question with regards to power supplies.
    When power supplies are labeled, they are usually labeled with both Voltage and Current, or say Voltage and Power.
    My stupid question is as follows:
    When a power supply says " 5volts, 6A" what does that actually mean ? like its supplying a voltage of 5 volts and 6 amps? but doesn't the current depend on the resistance of the load or whatever I connect up to the power supply ?
    Thanks guys, I know its a stupid question, but i'm sorta blacking out.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What the spec means is that the output will be pegged at 5V plus or minus some tolerance for any amount of load current from 0 Amps up to and including 6 Amps. At a load of more than 6 Amps different supplies will do different things, but for sure the output is no longer guaranteed to be 5 volts plus or minus some tolerance.
    A current limited supply may shut off very abruptly if the current limit is exceeded. Another supply may supply 6.5 Amps at 4.61 Volts or 7 Amps at 4.28 volts. The supply gives more current, but at a lower voltage and the maximum power remains the same.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings Mazaag,
    The current stated on the power supply refers to the amount of current that the supply is rated to deliver to the load. As you stated, the percentage of that available current used is governed by the load to which it is connected.
    hgmjr
  4. windoze killa
    Feb 23, 2006
    605
    24
    The current rating on a power supply is normally the maximum "continuous" current the power supply can deliver to the load. There are sometimes other ratings which may include peak current ratings. Your 5V 6A power supply may have a peak current rating of 10A. This current will only be for a short period of time, maybe half a second or so.
    As Papabravo stated what can happen when you exceed the rating may vary. Reduced volage, shutdown and unfortunately in some poorly designed ones it may even let the smoke out.
