Power supplies and Amperage!!
Discussion in 'General Electronics Chat' started by electronewb, Apr 28, 2012.
  1. electronewb
    Apr 24, 2012
    260
    Let's say an electronic device is rated for a power supply at 12VDC @ 1A Would it be OK to use a power supply if the voltage is the same in that case 12VDC but at higher amperage?
  2. #12
    Nov 30, 2010
    16,665
    7,312
  3. electronewb
    Apr 24, 2012
    260
    Thanks!! That's a good read!
  4. #12
    Nov 30, 2010
    16,665
    7,312
    There is a certain level of n00bie that it fits just right, and you asked just the right question to be a likely fit.
    Glad I could point ya' to it.
  5. electronewb
    Apr 24, 2012
    260
    The comments aren't too flattering to the writer of that paper!!!
  6. electronewb
    Apr 24, 2012
    260
    So basically the voltage has to be the same but the amperage will work as long as it's equals or above the device rating So in that case a 12VDC 100Amp supply would work?
  7. P-MONKE
    Member
    Mar 14, 2012
    83
    5
    Yep.
    But it would cost rather more than the supply you would actually need. :D
  8. mozikluv
    Jan 22, 2004
    1,437
    hi,
    were's the logic of using a 100A PSU? of course it will work because the current that will be drawn will only be what the device requires.
    mozikluv
  9. P-MONKE
    Member
    Mar 14, 2012
    83
    5
    I think the poster was being hypothetical.
  10. MrChips
    Oct 2, 2009
    12,624
    3,451
    Not quite. A 12VDC 100A supply is a car battery.
    When you are prototyping and experimenting you do make mistakes sometimes.
    Have you ever shorted out a car battery? The results are spectacular.
    You need a power supply that has short circuit protection.
    For simple electronics experimentation, a simple 9VDC @500mA adapter into a LM7805 voltage regulator is a better choice.
  11. #12
    Nov 30, 2010
    16,665
    7,312
    and yet, there is a certain audience that it is perfect for...like you.
    The result? I don't send "hopelesly pedantic" people to read it (as one of the criticizers signed himself).
  12. electronewb
    Apr 24, 2012
    260
    My question was hyper hypothetical Just making sure that the theory is right!!!
  13. #12
    Nov 30, 2010
    16,665
    7,312
    Yep. "Enough" is all you need. The excess won't be used.
  14. MBVet05
    Jul 21, 2011
    27
    You should always use a power supply rated at or just above what is needed. If you need a 12v dc at 1A then a power supply rated at 1-30vdc at 3a is suffiecent.
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    My car battery can supply 800A when cold to a cold starter motor.
    But the clock in my car draws only 0.01A or less, not 800A.
    PackratKing likes this.
  16. Lundwall_Paul
    Oct 18, 2011
    222
    19
    You could use a 60 Amp car battery if you wanted.
