1. moorejohn90
    Dec 9, 2011
    57
    Hi everybody,
    I want to create a circuit which involve arduino Pro Micro, BLE breakout board and GSM breakout board.
    I would like to know how to give power to these three.
    For Arduino ProMicro, there is no big deal. I know how to do it? That require 5V
    For BLE breakout board, that also require 5 V.
    For GSM breakout board, that also require 5V.
    For accelerometer, it require 3.3 V.
    Do I need to give 4 different power(four different DC adapter) source by connecting ground together?
    Can I used only two, 5V for ProMicro, BLE and GSM and 3.3V for accelerometer. If I can, how to connect these three to power line (in serial or parallel).
    Kind Regards,
    John
  2. GopherT
    Nov 23, 2012
    6,303
    4,021
    Use one supply for all of your 5V devices (parallel connection). All share the same ground and all share the same 5V. This assumes that your 5V supply can supply all the current they need (three devices added up). The fourth needs either it's own 3.3 supply or a low-dropout regulator feed from the 5V source used by the other devices. Make sure to connect the ground (0V) to the rest of the devices.
  3. moorejohn90
    Dec 9, 2011
    57
    Dear GopherT,
    Thank you for your guidance.
    Kind Regards,
    John
