Power source for Mini-Circuits oscillator
Discussion in 'Wireless & RF Design' started by Gunnar H. Laier, Mar 23, 2015.
  1. Gunnar H. Laier
    Mar 23, 2015
    13
    Hi
    Anyone with mini-circuit device experience?
    I got an voltage regulated oscillator with RF out, 12 DV in and carrier input (ZOS-300)
    All connectors are sma, incl GND +12 V
    Which power supply do you recommend? Is the device active without carrier input?
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    there is no rf input, there are two rf outputs, both sma, a tune input (1 to 16 vdc) and a couple of terminals for power,(18 volt max) if you already have a source of 12 vdc in your project, use it. if not, any supoly rated for at least 120 ma at 12 vdc will work. preferably regulated.
  3. Gunnar H. Laier
    Mar 23, 2015
    13
    Thanks! Do you know, if the circuits inside the ZOS series are similar across different frequencies. Are there fundamental differences. Would I be able to use another oscillator IC inside my current device?
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    they should be similar at least ones with similar frequencies. might be some differences between lowest and highest frequency units. should all connect the same, and use the same power and tuning voltages.
  5. waleed030
    Apr 4, 2015
    The circuit resembles a full wave rectifier. Also can anyone elaborate on which all capacitors/inductors are short or open or reactive to these three frequency components?
    _________________
    aliiii
