power SCR healthyness
Discussion in 'General Electronics Chat' started by bathampk47, Jan 26, 2006.
  1. bathampk47
    Jan 26, 2006
    how to check power SCR healthyness by multimeter/ CRO.
    regards
    Batham
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Your meter should be good for the test. Out of circuit, the SCR should check open C - A and A - C. The gate will show conductance to the cathode, probably in both directions. As long as it is also open when checking to the anode, all should be well.
    If you want to check by o'scope, make sure the circuit common is shared by the 'scope. Otherwise, you may blow up your vertical amp. Probe at some point past the SCR, and see if the waveform is controlled. It should be no more than 1/2 cycle, and show a decrease in conduction as the gate is controlled to smaller conduction angles.
  3. chesart1
    Jan 23, 2006
    269
