I have a standard "Bosch" type SPDT relay that will activate and send 12v of power to a power resistor (to automatically drain a battery). All I'm trying to do is to send power through the resistor and also turn on a LED to let you know that it is receiving power.
Let me apologize for the bad drawing, but this is what I have:
It works fine if I connect it directly to a 12v source, but when connected through the relay, the relay will spasm and open and close non-stop very, very quickly.
The circuit leading to the relay works fine as I can activate the relay and turn on a simple light bulb- the problem is something to do with this little resistor setup.
Any idea why this is happening?
