power resistor as heater
Discussion in 'Electronics Resources' started by legolas11, Mar 24, 2014.
  1. legolas11
    Feb 26, 2013
    55
    i want to use power resistor to heat up a surface from (30~70 degre celsius).
    the area is quite small 3x3 cm and so i want to use single small power resistor
    and a control circuit.
    Can someone recommend me a power resistor for this purpose?
    i want to use it with a supply around 12 v from dc supply.
  2. ericgibbs
    Jan 29, 2010
    2,575
    389
  3. MrChips
    Oct 2, 2009
    12,623
    3,451
  4. crutschow
    Mar 14, 2008
    13,469
    3,356
    If you use the bolt-on type resistor be sure you use a thin layer of thermal grease to mount it on the plate.
