power relay
Discussion in 'General Electronics Chat' started by shoshani, May 7, 2010.
  1. shoshani
    Nov 2, 2009
    I would like to use a relay complying with the following features:
    circuit configuration: Normally closed or SPDT
    Contact ratings: 50VDC \ 10Amp
    Coil voltage : 12VDC
    Mount type: PCB through hole
    Can someone help me with with this?
    Appreciate your help.
    Thank you.
  2. BMorse
    Sep 26, 2009
    2,675
    234
    depending on where in the world you are located, you can enter these criteria's in a search form for a supplier such as Digikey, Newark, Mouser, etc. and you will be able to find what you need.
    B. Morse
  3. retched
    Dec 5, 2009
    5,201
    313
    There are thousands of relays that will work fine at those specs.
    Any SPDT with a 12v coil and 50v and above and 10Amp and above.
  4. VoodooMojo
    Nov 28, 2009
    503
    53
