Power regulator.
Discussion in 'General Electronics Chat' started by FroceMaster, Apr 25, 2015.
  1. FroceMaster
    Jan 28, 2012
    402
    Hi
    Have these 3 version of regulators.
    Wich one will be best or suggestion to other.
    I have 12-18 dc input and will need outputs at 8v 200mA and 5v 20mA.
  2. Dodgydave
    Jun 22, 2012
    5,138
    767
    use the circuit in pic3, with all the caps connected to input and outputs , assuming the input voltage is 18v, then you will be dropping 10v @ 200mA thats 2W so a descent heatsink is required.
  3. ErnieM
    Apr 24, 2011
    7,434
    1,625
    None of the above.
    Reason being there is no outputcap on the 5V output. These are very old designs and they tend to oscillate, especially with no or light loads.
    The large input cap may or may not be needed depending on the input source.
    The large output cap again may or may not be needed depending on the nature of the loads.
    Since it is far easier to remove parts than to add them later plan forthem all, and if you wish later remove them one by one and see what happens.
    As someone once said, "you can't put too much cap on a power regulator."
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    What do you think the 1N4148 on the input is there for?
    If it is there for reverse polarity input protection, it needs to be rated for much higher current. The goal is blow an upstream fuse before the diode vaporizes. A 1N4148 will vaporize long before any fuse...
  5. FroceMaster
    Jan 28, 2012
    402
    Input voltage is around 12-14v dc from maybe a 230v ac adapter
    i will need 8v dc 200 mA and 5v 20mA for driving PIC 16F1509
    Any scematics to a decent and simpel power regulator ?
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    You can put too much cap on the output!
    If it discharges backwards through a 78xx, the regulator is toast.
    A lot of people piggy-back a 1N4001 pointing backwards so it doesn't conduct in normal operation, if the input cap drops faster than the output at power off, the diode bypasses the discharge current.
