Power output
Discussion in 'Homework Help' started by GirishC, Jan 29, 2010.
  1. GirishC
    Thread Starter Active Member
    Jan 23, 2009
    58
    This has equivalent circuit as a voltage source connectoed to load via 200ft cable.
    First we need to calculate the input voltage based on the given load output.
    Then replace output load and cable by 100 ohms load. With this new load calculate
    output voltage.
    Step 1:
    Po = 56.5dBuV = 20*log(V0/1exp-6)
    solving, we get
    Vo = 668.34uV
    therefore Po in dB is
    Po = 10*log(668.34exp-6/1exp-6) = 28.25dBuW
    Step 2:
    The cable loss can be calculated as
    Cable Loss = 4.5 * 200/100 = 9dB
    Step 3:
    This is power in the load of 50 Ohms.
    The power at the input of the load is give by
    Po = cable loss + Pin
    Pin = 28.25 + 9 = 37.25dBuW = 10*log(Pin/1exp-6)
    Pin = 5.31mW
    Vin = sqrt (Pin*50) = 515.21mV
    Step4:
    No with this input, reaplce 50 Ohm load and cable by 100 Ohms load
    and calculate Vo
    Vo = (100 * Vin)/150 = 343.47mV
    Vo = 110.72dBuV
    I do not understand what is wrong with the procedure I am following.
    The answer is given in the bracket in problem statement.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Remember dBuV is a voltage expression - not a power expression.
    I would proceed as follows
    (1) Work out the voltage at the cable input [Zo=50Ω].
    Voltage at cable input = 56.5dBuV + 9dB= 65.5 dBuV
    (2) Convert 65.5 dBuV to absolute voltage. 65.5dBuV <=> U uV.
    (3) Remember this absolute voltage is half the source voltage since the source has 50Ω output impedance.
    (4) Source voltage = 2*U volts
    (5) Remove the cable and place the 100Ω load.
    (6) V_100Ω_load = 2*U*(100/150) - it's a voltage divider.
    (7) Convert Vload to dBuV - I get 67.999 dBuV rather than 67.98 dBuV
    You've made several mistakes along the way.
    For instance .....
    You calculated Po with the cable in place as 28.25dBuW
    You (correctly) have Vo = 668.34uV = 668.34e-6 Volts
    So Po=Vo^2/50=(668.34e-6)^2/50 Watt = 8.9337 nW = 8.9337e-3 uW
    Po=8.9337e-3 uW <=> -20.49 dBuW
    In reality you don't need to go to the trouble of calculating powers - you can do it all in volts. But however you do it, take note of step (4) above in my method.
  3. GirishC
    Jan 23, 2009
    58
    Thanks a lot...I really did not know where I was going wrong.
    The reason I converted to power is to make sure I do not mess with voltage ration in dB...though it is essentially a power.
  4. JoeJester
    Apr 26, 2005
    3,393
    1,212
    0 dB/uV is 1 uV.
    0 dBm is 1 mW. Converting that to a voltage it is (0.001 * 50)^.5 or 223.6 mV. Converting 0 dBm to dB/uV is 20 log(223.6 mV / 1 uV) is approximately 106.9897 dB/uV or rounded off to 107 dB/uV.
    The question asked "Determine the reading of the meter on the source dBm."
    65.5 dB/uV - 107 dB/uV = -41.5 dBm
    The cable length, attenuation, and resultant dB/uV were distractors.
