Power output of those micro 30 rpm 6v gear motors on eBay
Discussion in 'Power Electronics' started by bobby500, Aug 29, 2016.
  1. bobby500
    Aug 26, 2016
    8
    If anyone has those little 30 rpm 6V gear motors, could they measure the voltage and short circuit current output at maybe 60 rpm?
    I'm making a mini crank flash light.
    Thanks.
  2. tcmtech
    Nov 4, 2013
    2,117
    1,753
    I would say probably 2/3's their voltage rating at whatever amp rating they have would be a good estimate based on an even 30 RPM feedback.
  3. Bernard
    Aug 7, 2008
    4,240
    414
    That will be a hard crank @ 100 : 1 reduction.
    tcmtech,, that is about what I measured with a driven step motor.
  4. Kermit2
    Feb 5, 2010
    3,852
    968
    Are you sure you can back drive it?
    If there is a worm gear anywhere in the reduction train you will not be able to move it from the output shaft side.
    shortbus likes this.
