i'm deploying this 4bit counter (HEF4520B) in my automotive application. question is, when these counters power on what are the output states? will it power up with with outputs set to zero, or is there a possibility it could power on and have random outputs set high? this is important info for my application and as such i do not want to build in a timed master reset after power on before it can be used, etc.
thanks
thanks
