I have built a voltage controlled current source for a project at school and am currently trying to spec the components I need to actually build the circuit. The circuit is shown below.
I realize I should just be using an op-amp but this isn't allowed in the design nor is a voltage regulator. P.S. The small 1u resistors are just to show me current through the MOSFETS.
This is a run down of current through the mosfet / power dissipated:
X1 52mA 55mW
X2 53.4mA 1.04W <---PROBLEM
X4 26.7mA 535mW
X5 26.7mA 354mW
X3 26.7mA 25.8mW
X6 26.7mA 510mW
X7 500mA 3.75W <---PROBLEM
Since this is a differential amplifier X4 and X5 should match (ideally) as well as X3 and X6. The idea would be to buy a single N-MOSFET for X1,X2,X4, and X5 and a single P-MOSFET for X3 and X6. Obviously X7 is the largest problem with X2 a close second. The only thing i have thought of doing is adding MOSFETS in parrallel to disperse the power. The problem is even doing this I will need over 5 MOSFETS to compensate for it and thats being optimistic. I know there are power mosfets rated for 2W + but I also know this is if you had an infinite heat sink which I currently dont have . If someone could point me in the direction of a MOSFET that can handle this kind of power and ones to handle the smaller requirements that would be perfect. Thanks in advance!
X1 52mA 55mW
X4 26.7mA 535mW
X5 26.7mA 354mW
X3 26.7mA 25.8mW
X6 26.7mA 510mW
