Power Meters, what have you used them for , what kind of circuits?
What were you measuring when using a power meter?
Circuits in which I wanted to know how much power was being used.Power Meters, what have you used them for , what kind of circuits?
Uh... power?What were you measuring when using a power meter?
Measuring power. What else would you be measuring?Measuring what with a power meter for single phase and 3 phase
You can't tell. That's why I said that you have to made additional measurements. If you disconnect the load and connect a resistive load instead and the meter still shows harmonics, guess which is dirty.If the incoming is dirty the harmonics would be what?
If the the load is dirty the harmonics would be what?
Before I know how best to explain, I need to know whether you understand what harmonics are. Do you? Please briefly describe what you believe them to be.The AC outlet is 60 hz
The harmonics should be what for a clean AC outlet 60hz signal?
Any linear load is going to be clean.The resistive load is dirty?
What harmonics are clean and what harmonics are dirty?
Are the clean harmonics 1,3,5,8?
the dirty harmonics 2,4,6,7?
The AC outlet from the wall has harmonics too right?
by Duane Benson
by Duane Benson
by Duane Benson
