Power loss
Discussion in 'Homework Help' started by kvi037, May 17, 2013.
  1. kvi037
    May 17, 2013
    17
    Can anybody help me with this problem?
    The voltage across the inductance and resistance in series LR circuit is
    v= 141,4 cos wt and the current through the resistive portion of the circuit is iR = 2,80 cos (wt-pi/6). Calculate the power loss for the circuit.
    Correct answer should be 173 watts
    I appreciate it a lot if you can help me:)
    Thanks!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    What working can you show thus far?
  3. kvi037
    May 17, 2013
    17
    Thanks for reply.
    I started to figure out Z by:
    Z= Û/Î*agle(-pi/6) = 100/1.97* angle (-pi/6) = 50.75 + j0.46
    P = i^2 *R = 1.97 ^2 A *50.75ohms = 198.4 W
    But this is not giving me the right answer. Do you have som suggestion for a better way to do it?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Your Z value is wrong. Probably because you are using your calculator in degrees mode rather than radians mode. The angle ∏/6 is in radians.
    kvi037 likes this.
