Hello there,
Any one ever use one of these things?
These are devices that raise or lower the line voltage depending on the current line voltage. For example, if the line goes down to 90vac it will still put out about 120vac, and if it goes up to 140vac it will still put out 120vac, approximately. Supposedly they also filter to make the wave cleaner.
When they post the spec's they are not that detailed. They spec for example 89 to 140vac input. That means that any input voltage like that will cause an output voltage of close to 120vac. But what happens if the line goes down to 80vac, or maybe even 70vac? Does it attempt to bring the line up higher, maybe to 110 or 100vac, or do they cut out?
