power line communication interface
Discussion in 'The Projects Forum' started by M0sTaFa, Dec 10, 2010.
  1. M0sTaFa
    Dec 10, 2010
    Hi all
    I am working on a project in power line communication, and i need to design an interface with the power line.
    i am using the ST7540 FSK-Transceiver on a frequency of 132.5 KHz
    i can see that i need to design a filter, my problem is do decide the specifications for this filter and how to make this done.
    i will be thankful for any informations. ;)
  2. retched
    Dec 5, 2009
    5,201
    313
    Be careful. That is the BEST info I can give. You can not learn if your dead.
    Obviously you are going to NEED to scope and monitor the signals on the power line, so I would implore you not to die.
    Ever. ;)
    Use a transformer to isolate the line from your probing setup and yourself. Shock hazards are in almost EVERY aspect of your project.
    Filtering out the 50/60hz signal should be relatively easy. Look for line hum filters.
  3. M0sTaFa
    Dec 10, 2010
    ha ha :)
    yes, i know that.
    but my problem was in the filter design.
    thank you i will see the hum filters.
  4. retched
    Dec 5, 2009
    5,201
    313
  5. DickCappels
    Aug 21, 2008
    2,756
    666
  6. M0sTaFa
    Dec 10, 2010
    thank you every body. :)
    i have one more quassion, if any one have used the ST7540-Transciver, i need to know what hapen if it detect signal on both the logic one, and the logic 0 filters, what will be his dession (1 or 0 )????? :( :|
    please help me
  7. Engr.sjsharma
    Dec 1, 2011
    dear im also working on this interface if u have got proper things kindly share with me.thnks in advance
