Power LED Driver
Discussion in 'The Projects Forum' started by 4beowulf7, Jul 25, 2015.
  1. 4beowulf7
    Jul 25, 2015
    20
    5
    Hi guys!
    This circuit is simple yet powers up 1-5W IR LEDs with constant current. Any idea to make a pulsed LED driver?
  2. ronv
    Nov 12, 2008
    3,401
    1,471
    Just pull the gate of the FET to ground with another small transistor.
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    If you want to use it as pwm control then you can using a 555 pwm, and the output connect to the (+) of U2 LM358.
  4. 4beowulf7
    Jul 25, 2015
    20
    5
    Thanks!
  5. RodneyB
    Apr 28, 2012
    652
    14
    What is the wattage of each of the resistors shown in your drawing
  6. 4beowulf7
    Jul 25, 2015
    20
    5
    For Figs. 2-3-4, I used a 1Ohm 2W resistor as R3. Rest were 0.25W.
    For the 0.33 Ohm resistor in Fig. 1, I don't remember the Wattage. It was about 3cm long ceramic resistor.
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    With the op-amp versions, a resistor could be inserted between the inverting input and the current sensing resistor, that would allow an added transistor to pull the inverting input high - sending the op-amp output low.
