Power Keyfob off 12v instead of CR2032
Discussion in 'Automotive Electronics' started by NoSloppy, Nov 29, 2015.
  1. NoSloppy
    Nov 29, 2015
    Hello! First post. I've searched, not found my answer (similar, but not same), then registered to get help on a simple question.
    If I were to hardwire my OEM lock/unlock keyfob to be powered off 12v instead of the 3v CR2032, can I get away with a 5v "cell phone" charger, possibly with a resistor wired in series to get even closer to the 3v?
    I will probably just end up using the battery and leave the buried keyfob somewhat accessible to change when needed, but that's no fun!
    Thanks for entertaining this.
  2. KJ6EAD
    Apr 30, 2011
    1,426
    364
    You can use a standard USB charger (5V) with three silicon power diodes (1N4001, etc.) in series to drop the voltage down to 3V. Be sure to put the diodes in the correct polarity direction (cathodes towards negative).
  3. NoSloppy
    Nov 29, 2015
    Perfect. Thanks much!
  4. Nepenthes
    Dec 18, 2015
    14
    Thanks KJ6EAD. Helpful to know as I will be doing something very similar.
