power inverter
Discussion in 'General Electronics Chat' started by whiz kid, Oct 13, 2010.
  1. whiz kid
    Oct 13, 2010
    Hi folks
    i want to build a 500 watt power inverter for user during power outages which are quite common in Africa and need help on how to build.I have no idea inverters
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    A UPS is a common request.
    Common answer is: It's cheaper to buy than build.
  3. steinar96
    Apr 18, 2009
    239
    It sounds that you do not have much knowledge of electronics. In that case the odds of successfully building a working 500W power inverter are quite slim. And as mentioned earlier. Buying one is usually cheaper then building.
  4. R!f@@
    Apr 2, 2009
    8,787
    771
    Why does everyone who has no sufficient knowledge wants to build heavy duty stuff.
    They always think this is so easy
  5. HUMBLE
    Oct 24, 2010
    28
    I understand where he is coming from.In Most African countries ,you see advertised everyday in the radio and TV , seminars on 'how to build your own inverter' in record time.
    What those organizers of the seminars are not telling them is that they cannot build it from scratch without returning to them for a fee.
    I guess that is the reason why you need the info to build an inverter.But as the others have posted,it would be better to buy a new one than to make your own Considering your state.
    Just consider how many times you will call-on and pay the seminar organizer for consultation,think of the time.
    But if you are so keen on building one yourself,then you can start your quest with much reading -making Google and Wikipedia your friends .
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Rather than trying to build an inverter, why not investigate using LEDs for lighting and 12v fans for cooling? Using LEDs will be far more efficient than trying to power incandescent lamps from an inverter.
    Charging and discharging a battery is not 100% efficient; closer to 70%-85%. For every Watt of power you put into the battery when charging it, you might only get 3/4 Watt output, depending on how heavy the load is, and the condition of the battery.
    Commercially manufactured inverters can be rather efficient, topping 90%. A home-made inverter is more likely to be around 80% efficient, if that good. The more efficient the inverter is, the lower your operating costs will be over the life of the inverter.
    Commercially manufactured inverters are really not that expensive, either - and they generally come equipped with batteries, so they are ready-to-run. However, keep in mind that most UPS'es designed for use with computers are generally rated for around 10 minutes of operating time before they shut down due to the battery being exhausted.
  7. soda
    Dec 7, 2008
    174
    13
    Hi
    You don't say from which part of Africa you are, but if you from SA you can order a 500w inverter from Rabtron in Joburg. You pay about R600 for it.Go to a place like Battery King and tell them you want a 12v 100Ah deep cycle battery. The batt. will cost in the region of R1800. Use the batt. to drive the inverter when you have a power failure.
