The 4 mosfets were Replaced the mosfets they blew again Irf3205 TO 220 case. Can the IRFP064N with a TO 247 case be substituted they both list N-CH 55V 110A for specs but case style is different do both the irf3205 and irf p064n have the same pin out? What else should I Test on this inverter. None of the ic's are burnt however I seen a smd resistor attached to one of the mosfets on the back of the board looks like it cooked printing not readable at all I know the value though. I appreciate any help with this. thank you
