Sir,
1) The resistance of a parallel c/t consisting of two resistors is 12 ohm,one of the resistance wire breaks and effective R becomes 18 ohms,find the R of of broken wire.
2)Two lamps of 200w 220v and 100w ,220v are connected in series across 22ov supply.Find ratio of I thru them will be ?
3)Two heaters rated at 1000w,250v each are connected in series across a 250v,50hz ac mains.Total P drawn from supply would be ?
4)The resistnce of 100w,220v lap to that of a 100w,110v lamp will be at ___ respective voltages .
