Power in a AC Series LCR Circuits.
Discussion in 'General Electronics Chat' started by asimbhawsinghka, Oct 28, 2007.
  1. asimbhawsinghka
    Aug 2, 2007
    7
    After pondering for few hours over the power triangle in a series LCR circuit, i came to realise that the various sides of the triangle, represnting the powers, viz. active power, reactive power and apparent powers are basically powers of purely resistive circuits with resistance values the same as that of the impedence values as that of the various components of the LCR circuits. Am correct in visualizing it?????
  2. chesart1
    Jan 23, 2006
    269
    At the resonant frequency, the inductive reactance and the capacitive reactance cancell each other out. You are left with pure resisitance. At all other frequencies, you will have some reactance.
  3. Dragon
    Sep 25, 2007
    42
    You are not exactly correct about it. REAL & REACTIVE powers are used to differentiate between the type of LOAD at the ouptut, which can be purely resistive, inductive, capacitive or a combination of these.
    REAL POWER - For purely resistive loads.
    REACTIVE POWER - For inductive/capacitive loads.
    APPARENT POWER - It is the vector sum of real and reactive power.
    A practical load will have resistive, inductive, and capacitive parts, and so both real and reactive power will flow to the load.
    Reactive power indicates whether power is being transferred to the load from the source, or from the load back to the source.
