Power for TTL circuit
Discussion in 'The Projects Forum' started by jgessling, Sep 28, 2014.
  1. jgessling
    Thread Starter Active Member
    Jul 31, 2009
    75
    15
    I'm gearing up for my second TTL project. One of the issues that bugged me before was power. I had taken a nine (sorta) volt wall wart and ran it through a DM317 to get regulated 5 volts. Never really liked this since it put out a lot of heat, made the heat sink really warm. This time I was thinking that since USB is 5 volt that might be an option. I have an apple iPad charging thingy and it puts out about 5.1V (no load) with up to 2.1A output. That's plenty of amps but I wonder about the voltage regulation. Will this be OK? Sure would be convenient. Thanks for any thoughts.
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Best I can say is to try it. A battery charger may be able to handle more ripple then TTL will, but 5.1V no load is safe for the logic.
    Some extra capacitance may one day be necessary so keep that in mind.
  3. ronv
    Nov 12, 2008
    3,404
    1,478
    You may be more careful than I am, but I wouldn't let some of my circuits close to my usb port, :)
  4. DickCappels
    Aug 21, 2008
    2,777
    674
    The +5 on USB is +5V±0.25V, which is compatible with TTL, provided you don't have a significant voltage drop in the cable leading from the USB connector.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Think old phone charger.
    Or a 6VDC battery with a silicon diode and Schottky diode forward biased. This will make a 5V source.
  6. jgessling
    Jul 31, 2009
    75
    15
    Thanks all. What I've got is an Apple phone charger that also works on iPad so it's got more "oomph" but same voltage. Nice to hear from Bill he's helped me and many others.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Think of a Thrift store as a source of ready-made, cheap, well-regulated wall-wart power supplies. My local Habitat for Humanity Thrift Store sells odd wall-warts for $1. I always check there when I am in town. Bought two just last week...
