Power factor
Discussion in 'Homework Help' started by kwb, Nov 9, 2011.
  1. kwb
    Nov 9, 2011
    I need to calculate the power factor of a single phase circuit which has a phase angle of 60 degrees between the current and the voltage. Can anyone help?????:D
    If q is the phase angle between the current and voltage, then the power factor is equal to the cosine of the angle. I am not sure how to use the equation and dont really understand the question.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    The Homework Help section asks that you post up the work you have done so far, so we can see it and find where you went wrong, or suggest better approaches. We will not do all your work for you, no matter how little time is left before it must be submitted.
    If you are in doubt about how to structure your post and what to include please read this thread: http://forum.allaboutcircuits.com/showthread.php?t=3002
    Thank you.
  3. jimkeith
    Oct 26, 2011
    539
    99
    simply look up:
    "Power factor definition"
    kwb likes this.
  4. crutschow
    Mar 14, 2008
    13,493
    3,372
    You answered your own question. Do you not know how to determine the cosine of an angle?
