Power factor for three phase
Discussion in 'Homework Help' started by TAKYMOUNIR, Jan 10, 2012.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    How can i make power factor for three phase
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Perhaps you could make your question a little clearer. I'm not sure of what you are asking.
  3. TAKYMOUNIR
    Jun 23, 2008
    351
    i mean improve the power factor for the three phase line to make voltage and current in phase
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    If the uncompensated power factor is lagging you can use power factor correction capacitors specifically designed for that purpose. What's your particular application?
  5. nyasha
    Mar 23, 2009
    90
    Capacitor Bank in parallel with the load will improve the power factor.
  6. amilton542
    Nov 13, 2010
    494
    64
    It depends on t_n_k's question, what is the application?
    For example, does the industry in its entirety all turn on and off at the same time? The solution would be a fixed value of PFC.
    Conversely, would it be easier to switch capacitors in-and-out through a PLC governed by a PF that varies?
