power factor correction...
Discussion in 'General Electronics Chat' started by dolphi, Jan 19, 2009.
  1. dolphi
    Dec 27, 2008
    5
    Hi all...
    How boost converter s used for power factor correction after rectification...?? Could anybody here pls explain me ths concept.... am very mush confused.... after rectifying an ac supply to dc, how will the boost converter helps in correcting power factor...??:confused:
  2. mik3
    Feb 4, 2008
    4,846
    63
    Correcting the power factor of what?
  3. gotumal
    Mar 24, 2008
    99
    dolphi means power factor of a system; cosine of the angle between current and voltage.
  4. mik3
    Feb 4, 2008
    4,846
    63
    I know what is the definition of the power factor but the question is not clear, at least to me.
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    "Power factor" implies AC. "Rectification" and "boost converter" imply DC.
    The question seems to be about rectified & filtered higher voltage lower current -vs- rectified & boosted lower voltage higher current. Is power factor of the primary different between these two. If so why?
  6. n9352527
    Oct 14, 2005
    1,198
    I think the poster asked why boost converter is often used in PFC stage of a SMPS. It is a common design approach to use a first stage boost converter in a largish SMPS to improve the overall PF of the SMPS.
