A 400hp SCIM and a 400hp synchronous motor both operating at 90% efficiency. The SCIM (Squirrel Cage Induction Motor) power factor is 0.8% lag. The synchronous motor power factor is unity. How many amperes of incandescent lighting may be added to the plant at the same kVA load if the synchronous motor is operated at a leading power factor of 0.8%? The supply is 600V, 3 phase. The answer to the question is 43.78A.
I am trying to work out the calculations to get the answer. So far this is what I have........
P motor output = hp x watts/horsepower......400 x 746/hp = 298kw.
P motor input = output power/% efficiency x 100 = 298.4kw/90 = 3315.56
3315.56 x 100 = 331.6 kw
Qt = Pt x tan(theta)
331.6kw x tan 36.87degrees
= 248.7 kvars
Thanks!
= 248.7 kvars
Thanks!
