Power factor correction problem
Discussion in 'Homework Help' started by testing12, Apr 11, 2011.
  1. testing12
    Jan 30, 2011
    80
    Hello ,
    I had to solve the following problem:
    I did this problem using admittance. (since there in parallel) I simply took the impedance above took Y= (1/Z)
    and
    G (susceptance) = 2(pi)fC
    i got C = 312 microfarads. My question is how did they do part b in the solution manual. Im not understanding that. Please advise thank you.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I wonder if it shouldn't be
    C=\frac{Ptan(\theta_1-\theta_2)}{\omega V_{rms}^2}
    where
    \theta=(\theta_1-\theta_2)
    is the angular difference between supply voltage and current
    and
    p.f.=cos(\theta_1-\theta_2)=cos(\theta)
    In any case that formula should be derived or stated somewhere in the text from which the problem is quoted.
    It's easy enough to show that
    Motor Reactive Power, Sm
    S_m=VIsin(\theta)=VIcos(\theta)\frac{sin(\theta)}{cos(\theta)}=P_mtan(\theta)
    Where Pm is the motor real power.
    The capacitive reactive power, Sc is
    S_c=\frac{V^2}{X_c}=V^2\omega C
    And assuming Sm=Sc for complete compensation.
    Leads to ..
    C=\frac{P_mtan(\theta)}{\omega V^2}
