power equation
Discussion in 'Homework Help' started by 0001T, Sep 24, 2007.
  1. 0001T
    Feb 28, 2007
    15
    I am doing a project to measure power required to heat up a wire. I will be measuring the resistance and voltage across the wire against time. Therefore I will have:
    resistance of wire = R(t)
    voltage across wire = V(t)
    I know power =V*R
    So am I correct to do integrate V(t)*R(t) from t=0 to t=t1?
    Thank you.
  2. arthur92710
    Jun 25, 2007
    307
    Im not sure about the rest but "I know power =V*R" is wrong
    Power = I*V Current times voltage
  3. 0001T
    Feb 28, 2007
    15
    thanks for the correction. u r right.
    so now my equation will be to integrate V(t)*V(t)/R(t) from t-0 to t-t1.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I believe you will find that power is actually V squared divided by R.
    hgmjr
