Power electronics
Discussion in 'Homework Help' started by ravenpowerful, Apr 7, 2013.
  1. ravenpowerful
    Apr 7, 2013
    A single Ph full bridge rectifier uses a uniform PWM with 5 pulses per half cycle.
    Determine the pulse width if RMS output is 80% of the dc input voltage
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    Did you note the name of the forum?
    Did you note that it is NOT named Homework Done For You?
    Did you notice where it said, "Post your questions and attempts here and let others help."?
    Post YOUR efforts to work YOUR homework and we will try to use that as a springboard to HELP (hence the forum name) you move towards a solution.
