Power Dissipation Issues
Discussion in 'General Electronics Chat' started by stdio.h, Feb 19, 2015.
  1. stdio.h
    Feb 18, 2015
    Hey!
    I built a circuit with a 5V power supply and a 300 ohms resistor. With a multimeter I did the measurements of resistance, voltage and current across the resistor. The values was:
    R = 298 ohms
    E = 4.94 V
    I = 16 mA
    So I made the calcs to obtain the power dissipated by the resistor:
    P = EI = 4.94 * .016 = 79 mW
    P = E²/R = 4.94² / 298 = 81.9 mW
    P = I²*R = .016² * 298 = 76.3 mW
    My question is: Why there are differences between the power results? It's because of the lack of precision in measurements, the increase of resistor's resistance when powered or a combination of both?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    The precision of the current is to low.
    The current will be 4.94 Volts / 298 Ohms = 16.5771 mA.
    When you do the calculations with this value the power will be 81.89 mWatt.
    Bertus
    stdio.h likes this.
  3. #12
    Nov 30, 2010
    16,704
    7,350
    Precision problems. I calculate 16.577 ma, but most meters don't go that far down in the digits. Neither do they measure closer than a tenth of an ohm.
    stdio.h likes this.
  4. stdio.h
    Feb 18, 2015
    So the problem is my HM-1000 multimeter.
  5. #12
    Nov 30, 2010
    16,704
    7,350
    You can spend big bucks for something that has 5 or 6 digits, but it usually doesn't matter unless you're servicing precision analog meters.
    Most people (including me) get along with a $10 POS except for rare occasions.
  6. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  7. stdio.h
    Feb 18, 2015
    Yes! I know. I was just justifying the lack of precision in my measurements. The HM-1000 is good enough for me.
  8. wayneh
    Sep 9, 2010
    12,389
    3,245
    Did you actually measure the 16mA current, meaning your meter was part of the circuit? That would introduce some series resistance and lower the current. If you have a second meter, you could measure the ∆V with the first meter in place.
  9. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Also, high precision meters take longer to get accurate measurements.
