Power Dissipation in transisitor !!!!
farhan89
Joined Feb 13, 2010
34
Hello all,
I have one question. When Ic and Ib are zero is there any power dassipation in Transisitor???
If Yes Then How???
Papabravo
Joined Feb 24, 2006
21,226
I don't think there is any power dissipation, but this sounds like a trick question. If you have information that says it is possible; clue us in.
mik3
Joined Feb 4, 2008
4,843
If there is a DC voltage across the collector-emitter then a small current will flow through the finite off resistance of the transistor. However, this through the collector. Another option, is to have an AC voltage and say there is power loss due to the small current flowing through the parasitic capacitance of the transistor.
I think the answer is that there is power dissipation due to the random motion of electrons in the transistor and vibration of the atoms of the semiconducting materials and this dissipation depends on the ambient temperature.
lmartinez
Joined Mar 8, 2009
224
In a perfect world, I would have to agree; that is, no power dissipated if no voltage source is applied on the transistor . However, there is a thing known as nanoscopic leakages in the materials utilized to make such devices. Hence, too broad of a question to advice.......
