Power dissipation across multiple resistors
tom66
Joined May 9, 2009
2,595
If I have a 100 ohm/0.25 watt resistor in my circuit I can dissipate 0.25 watts safely across the resistor \(\frac{{V^2}}{R}\). But what if I have two resistors... I now have 50 ohms, but how much power can I dissipate? What about multiple resistors of different values...?
Any help appreciated. This is not homework, this is for a project to make my own oscilloscope.
Tom
Externet
Joined Nov 29, 2005
2,220
Hi.
Two 0.25W resistors in parallel can dissipate 0.5W. Two 0.25W resistors in series can dssipate 0.5W.
Many resistors in parallel, or in series, can dissipate the sum of their rated power.
Miguel
gerty
Joined Aug 30, 2007
1,305
If you put 2 50Ω in series, it's still going to be .25 watt, since the current remains the same in a series circuit. Is this what you had in mind?
Externet, you beat me by 2 min!!
gerty
Joined Aug 30, 2007
1,305
Are you going to put them in series or parallel?
If you post your schematic we can help you without guessing.
SgtWookie
Joined Jul 17, 2007
22,230
It is good practice to use resistors which are rated for double the power expected in the circuit. If you expect 1/4W power dissipation, then use 1/2W resistors.
If you use 1/4W resistors with 1/4W actual power dissipation across them, it may cause the value of the resistors to change over time.
If you expect to dissipate 1/4W across a 100 Ohm resistor rated for 1/4W, then you have a few options:
1) Increase the rating of the resistor to 1/2 Watt.
2) Use two 200 Ohm 1/4W resistors in parallel.
3) Use two 50 Ohm 1/4W resistors in series. The closest standard value is 51 Ohms.
Audioguru
Joined Dec 20, 2007
11,248
A resistor operating at its max power rating is extremely hot. It will melt insulation and might char a pcb. It will burn you if you touch it. Don't operate a resistor at its max power rating.
tom66
Joined May 9, 2009
2,595
I know... I have burnt myself on a resistor before.
What I am asking is if it is possible to create a 1/2W resistor from two resistors at 1/4W. This is theoretical, I am not going to run them at 1/2W instead probably 3/4 the total rating (3/8W).
SgtWookie
Joined Jul 17, 2007
22,230
Yes. Double the resistance and connect in parallel, or half the resistance connected in series.
The "rule of thumb" still applies. I strongly suggest that you use resistors rated for at least twice the expected power dissipation.
Resistors are very cheap. No sense in ruining a board or project because you used under-rated resistors.
