Power dissipated in RC & RL circuits
Discussion in 'Homework Help' started by The knight, Jan 12, 2011.
  1. The knight
    Jan 12, 2011
    Greetings,
    I hope you are well, and I'd like to ask you about the power dissipated due to capacitor and inductor,
    For example, a capacitor, say 2μF connected to the independent votage source 20V, the the source is removed and replaced by a resistor in such a way that the voltage does not change instantenously, the resistor has a resistance of 5Ω. and the qusetion is find the time when the power dissiapted is 75% of the initial power?
    And what will be the time if we use inductor 2mH and do the process?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    On a resistor, the power dissipaded is \frac{V^2}{R}. Also, the voltage on the resistor will be described by the equation V_0 e^{-\frac{t}{RC}}.
    Therefore, the total power dissipated will be \frac{V_0 \cdot RC}{R} (someone correct me if I 'm wrong).
    Then you need to solve the integral from 0 to t and equate that to 3/4 of \frac{V_0 \cdot RC}{R}. Solving for t will give the answer.
    The knight likes this.
  3. The knight
    Jan 12, 2011
    Thank you,
    but when I saw solution in the the book, the author uses 1/3 rather than what you used. I don't why he solves like.
    My question know, why he uses the remaining presntage of energy to calculate the time needed to dissiapate 75% ?
    and In case of inductor, he uses the presnage itself not the remaining
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    As I posted, it is possible that I am wrong. I have never seen an exercise like yours so far. I put my logic down and solved it. Maybe if you write down what your book asks and suggests we will sort it out.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Perhaps the question is really asking at what time the stored energy in the capacitor has reduced to 75% of its original value - rather than when the power has fallen to 75%.
    The stored energy at time t will be given by
    W=\frac{1}{2}CV_c^2(t)
    For the energy to have fallen by 75% would require the voltage to have fallen to √0.75 of the original value or 86.6% at time t.
