Power Dissipated by Resistors
Elizabeth Paredez
Joined Mar 22, 2011
The only thing I know about resistors is that V = IR. I think I can simplify the circuit but I really have no idea how to answer the following questions.
What is the power dissipated by each of the resistors in the following circuit and what is the electric potential difference between points (a) and (b)?
Please any help would be greatly appreciated because I don't even know where to start.
Wendy
Joined Mar 24, 2008
23,429
Take the two parallel resistors, make them one, then you will have two series resistors. Make them one, then you have it.
Elizabeth Paredez
Joined Mar 22, 2011
Here's what I did.
V = IR
I combined the 2.0 Ω resistor with the 24.0 Ω resistor to give me "26.0 Ω" resistor. Since I made it a parallel circuit, volts are constant.
For R(equivalent) I got (26^-1) + (8^-1) = .163461....then ^-1 it equals approx 6.0
Then I did, I26 = V26/ R26 (12/26) and got approximately .5 Amps
Then I did, I8 = V8/R8 (12/8) and got approximately 1.5 Amps
Then I did, I(total) = V/Req (12/6) and got approximately 2.0 Amps
Does anybody know if what I did is correct???
Wendy
Joined Mar 24, 2008
23,429
You can't do it that way. You must combine the parallel, since both of them are in series with the 2Ω resistors.
Combine the two parallel resistors first.
Georacer
Joined Nov 25, 2009
5,182
The reason you can't combine the 24Ω and the 2Ω resistor is that they are neither parallel nor series.
They would be parallel if they had common endpoints.
They would be series if they had only one common endpoint, which would be unique to the two of them.
In your case, that endpoint is shared with the 8Ω resistor which spoils the "serial-ity".
saikat36
Joined Jan 28, 2009
16
U have 2 parallel resistor 24? & 8?.So
Req=(R1*R2)/(R1+R2)=6?
Now 6? & 2? r in series, so
Req=6+2=8?
then current I=(12/8)=1.5A
now branch current of 24? & 8?
I24=(8/32)*1.5=.375A
I8=(24/32)*1.5=1.125A
Power dissipation
P24=24*0.375*0.375=3.375W
P8 =8*1.125*1.125 =10.125W
P2 =2*1.5*1.5 =4.5W
Vab=-(2*1.5)=-3V
I think now all is cleared.
Thank u.
